Need help finding a few bits...?
- Coolhand78
does anyone know what the mini toggle switches that are used on the toneczar pedals are? they have a smaller arm/lever thingy than usual..?
i'm looking for one the same size to just use as an On/Off switch for the battery so the pedal can remain plugged in/wired up on my board...?
also, does anyone know where I can get the standoffs that Dave uses in the Sola Sound Benders...?
thanks for your help.
Re: Need help finding a few bits...?
If you search "SPDT switch" on ebay, you'll find loads.
Standoffs?
Standoffs?
- peps1
Assuming the bent aluminium bracket that mounts the PCB via the pots.Laundromat wrote:Standoffs?
- cajone5
I'm not sure what Toneczar uses but I use mini toggles all the time and they're available all over. Here are links to smallbear for example...
http://smallbear-electronics.mybigcomme ... toggles-1/
http://smallbear-electronics.mybigcomme ... ort-lever/
http://smallbear-electronics.mybigcomme ... ver-on-on/
http://smallbear-electronics.mybigcomme ... enter-off/
Timing has a lot to do with the outcome of a rain dance.
Oh. In that case...peps1 wrote:Assuming the bent aluminium bracket that mounts the PCB via the pots.Laundromat wrote:Standoffs?
- Lee
Isn't there a place that makes them on order or is my mind playing tricks on me again
pretty sure dave make his by hand.... i make my own too....
- Coolhand78
if i just want it to switch the battery on and off (such that i can leave the pedal plugged in and just flick the switch to disconnect the battery when not in use)cajone5 wrote:I'm not sure what Toneczar uses but I use mini toggles all the time and they're available all over. Here are links to smallbear for example...
do i need on-on or on-off? i'm assuming on-off-on switches have the 3 positions?
I really just want a good quality on off mini toggle switch? is this the one i'm looking for:
http://smallbear-electronics.mybigcomme ... -on-0218b/???
thanks for the help.
- moose
Yeah can just use two pins from that switch.
- cajone5
On-on will work. Just have the power (or ground) from the batterty run in to the center lug and out to the board through one side. Leave the other side unconnected. Then the wire will be broken when the switch is flipped. Someone smarter than me may provide preference of which to do (+ or -) for some reason but either should work.Coolhand78 wrote:if i just want it to switch the battery on and off (such that i can leave the pedal plugged in and just flick the switch to disconnect the battery when not in use)cajone5 wrote:I'm not sure what Toneczar uses but I use mini toggles all the time and they're available all over. Here are links to smallbear for example...
