I recently bought some batteries that deliver crazy 9.8V
Can this voltage do harm to my pedals? Should I rather not put one of these in my 1966 or Head Buzz or...D*A*M MkII ?
Can this battery harm the fuzz?
- norhyme
“Interviewer: 'So Frank, you have long hair. Does that make you a woman?' Frank Zappa: 'You have a wooden leg. Does that make you a table?” ― Frank Zappa
Narp. Every dollar store battery I buy reads over 10v and I've yet to have any problems.
- norhyme
thanks Cody!daCod wrote:Narp. Every dollar store battery I buy reads over 10v and I've yet to have any problems.
- stella_blues
Re: Can this battery harm the fuzz?
If in doubt, put the batteries in a delay pedal for a few minutes, that'll drain the power pretty fast
When you put a load of a pedal on the battery they will go down some because there is a built in resistance in the pedal.
- norhyme
Thanks- cool - was just wondering if higher the voltage could possibly harm the transistors but yall seem to be sure it won't. Anyway these batteries make some fuzzes sound over the top...maybe I'm just more used to the 9.5 V and lower batteries...I'll try to drain then a bitsir h c wrote:When you put a load of a pedal on the battery they will go down some because there is a built in resistance in the pedal.
In general 9V batteries are usually 9.6V, and most designs should be made with a 20% margin, so that would be 12V minimum (and then those tolerances have margins...)
- peps1
Users browsing this forum: No registered users and 16 guests
