thoughts/preferences on collector voltage in Range Master?
- vanguard
Curious what folks familiar with the circuit think. Geofex famously recommends around 7v. As I've built my own, and checked out builds of lots of great builders, I find voltage from 5v on through 7v. Lower voltage seems to yield a louder, cleaner, slightly harder effect, while 7v gives a slightly quieter, softer, fuzzier effect. It seems some builders simply do stock resistor values on every build and use transistors with hfe 70-150 or so. What do you folks prefer?
- jetofuj
Re: thoughts/preferences on collector voltage in Range Maste
- 666.JPG (225.7 KiB) Viewed 3050 times
- vanguard
Pretty sure that's daves setting for roosters!
Users browsing this forum: No registered users and 10 guests
