Gents,
Do you have any idea which glass component this is and where I can find a similar (if not the same) part?
Ross Compressor - Help Naming a Component
- thebends9
The Captain wrote: If you find a 'fake' transistor in a D*A*M pedal I will literally eat my own dick. Confident I am.
Re: Ross Compressor - Help Naming a Component
That's a silicon diode... Prolly 1N4148 or similar
http://www.mouser.com/ProductDetail/Fai ... fgodM20BZg
- thebends9
XOXO
- Ben Lyman
Jerms is probably right but I just wanted to mention that the Ross comp has two 1n914's (1n4148) and one 1n4001.
I think the one your arrow points to may be for reverse polarity protection and a 1n4001 is much better for that
Ben is correct.... That is the diode in the power supply....def put in a 2N4001 or 2N4002 in that spot.... I went and pulled my ross apart to confirm this...
Users browsing this forum: Semrush [Bot] and 12 guests
