Old 1985??? Ibanez pedal problem
Doc Holliday
Post by Doc Holliday » Wed Apr 18, 2018 10:21 pm
Ok, bought this pedal.
Sounds really good and not unlike a 80s TS9.
Although the tone knob sometimes works... and sometimes does not.
If I keep turning it on and off it’ll kick in and work.
This video demonstrates the pedal at first working.
Then after several on and offs it seems to resort to a fixed position regardless where you set the toneknob. It’ll sound that way all around the dial. Then by turning the pedal on and off again a few times it kicks in and works?!
Any ideas how powering the pedal on and off is effecting the tone knob???
Instagram : the_doc_holliday :tu:
rootfifthoctave
Re: Old 1985??? Ibanez pedal problem
Post by rootfifthoctave » Fri Apr 20, 2018 1:09 pm
Is the pot loose? I found that the pots on my ts9 can come loose and one of the lugs makes contact with the enclosure.
Doc Holliday
Post by Doc Holliday » Fri Apr 20, 2018 1:57 pm
I’ll have a look but I’ve took it apart and didn’t notice anything.
Thanks for the reply
Scruffie
Post by Scruffie » Fri Apr 20, 2018 7:42 pm
Can't think that the switching would be affecting anything, either a bad pot, bad solder connection or if this uses tantalum for the 220nF on the tone control, that could have gone bad and is working intermittently.
Doc Holliday
Post by Doc Holliday » Fri Apr 20, 2018 9:33 pm
Cheers Scruffie!
Scruffie
Post by Scruffie » Sat Apr 21, 2018 11:01 am
No problem! If you get stuck i'm in the UK and i'll sort it for the return postage.
