Just pr0n!
- Lee
Re: Just pr0n!
Always loved that Tele of yours. Someday I will find a '72 for a good price. Did t you build that white Jag Cody?
Thanks Lee. That 77 is going to the grave with me. The Jag is one of those FSR Sonic Blue AV65 reissues. It's mental
Lain you have a good eye. Couple non-Jerms on there but maybe one day that'll change
You have no idea Paula how many times I measured and marked and measured and marked and MEASURED & MARKED the spacing before settling on position.
I just eyeballed the wall mounts tho. Turned out meh.
- jagermonster
Looks great. Been thinking about doing something similar. What brand of hangers did you go with? Did you screw into the studs or are anchors sufficient?daCod wrote:ocd guitar hanging
not sure the brand. to be honest i probably could have made these myself. nothing fancy . i snagged these 5 for cheap from a guy on the offset guitar forum. there were 3 screw-in hook/hangers with them but i went out and bought 5 matching. appropriate mounting screws and anchors were included. was going to try and run them into studs but the planned spacing was not cooperating with the wall studs so i went with the anchors. they were EZ Ancor Stud Solver drywall anchors. looked them up and i guess they're rated at 50 Lbs. worked great. solid shit is solid.jagermonster wrote:Looks great. Been thinking about doing something similar. What brand of hangers did you go with? Did you screw into the studs or are anchors sufficient?
here are a few close up shots. the inside measures 2.25". plan is to put some heat shrink or some type of soft covering over the rubber so it wont end up jacking with the headstock finish.
- jagermonster
Re: Just pr0n!
OK, bitchin. Thanks for sharing. I just have such paranoia about my heavy ass Greco falling off the wall and breaking into multiple pieces...
- rafmax
- chankgeez
Re: Just pr0n!
That may be the most penetratin' pr0n I've ever seen.
0
