Philip wrote:theemadcap1 wrote:Laundromat wrote:On behalf of Stu?
These are the pics Stu posted in the 'I bought it' thread, instead of responding and posting there, I thought i'd start a new thread...?
Don't think there should be a problem...
Winter is kicking in big time in Europe, maybe making some of us more cranky.
Does yours flick between fuzz and wah, like Stu's, no clean bypassed signal? What were they thinking when they came up with that!?
Yea, it's cold here...nearly 55 degrees out...!
Yea, wah always on, only a footswitch for the fuzz off/on. No way to turn just the fuzz on, or to turn the wah off.
You would need a looper pedal to get it to work in a live setting.
Interesting how with these 3 pedals you can see the evolution.
1st one on Vero, in the MKIII pedal case, PCB still in MKIII case and then the Carlsboro in the MKIV case, all with a chrome wah pedal on top. The MKIII version is not tall enough, doesn't allow the pot to fully turn thru the whole sweep. On mine, someone cut a tiny hole in the bottom plate to allow it to turn all the way. Great sounding fuzz! Super thick! You can see on mine, I will need to change out the battery terminal. Got ripped off when I tried to change the dead battery.
