FOXX OD machine
- dirtgarden
FOXX OD machine
Got this for repair yesterday.
- jetofuj
is it like the Univox Uni-Drive? would be cool to hear the finished/fixed product Brian...
- dirtgarden
Haven't had time to try it out. Looks similar to the Clean Machine. Will attempt to upload a clip tonight.daCod wrote:is it like the Univox Uni-Drive? would be cool to hear the finished/fixed product Brian...
Identical!dirtgarden wrote:Looks similar to the Clean Machine.
- joegagan
Re: FOXX OD machine
got one of these off ebay , missing treadle, last year. am currently adding a treadle from a dearmond vol ped, but with a bunch of drilled holes to replicate a race car gas pedal. will post pics when done. red and black , baby!
from research, it seemed to be the same as the other foxx fuzzes in circuit ( 3 or 4 trans if i recall, it is at my store so i can't look at it) i presume that FOXX named it overdrive because in the mid 70s that was the new buzzword as fuzz started to seem a dated term.
a lot of guitarists think they would like treadle control for gain, but when given the opportunity they rarely bond with it. ask BOSS, their 1983 PD-1 was a dismal failure. it was a super overdrive with treadle control. discontinued quickly.
back to the foxx, i have seen them sell for around 225 on ebay in great condition, but other owners think they own a golden goose ( $500 !!???)
http://www.gbase.com/gear/foxx-od-machi ... -red-furry
- joegagan
dr tony, i will trace mine out to see if it matches the schem you posted. thanks for putting that up!
the sad thing about these i that they used tha huge cap at he end of the circuit board which forces that sorry ass bend in the circ board when mounted,. mine is even more bent than the one in the pic above.
edit- i just noticed the board in the pictured unit is CRACKED. the stres o the bend was too much.
- DiscoFreq
At least 1 small difference: the extra Boost knob on the OD Machine :DDr Tony Balls wrote:Identical!dirtgarden wrote:Looks similar to the Clean Machine.
EffectsDatabase: http://www.effectsdatabase.com
26000 pedals, 4000 brands
- dirtgarden
Looks to be the same as the Clean Machine but with an output cap blend. The 2 greenies are 47n.joegagan wrote:dr tony, i will trace mine out to see if it matches the schem you posted. thanks for putting that up!
Users browsing this forum: Semrush [Bot] and 5 guests
