Tips to get fuzz to play nice with a Hot Cake (buffer)?
- imguitardan
Amp situation has changed and I'm digging my Hot Cake over my Honey Bee for OD BUT I feel that the HC buffer (even when off - maybe?) is effing with my fuzz tone (Sonic VI Fuzzrite ). Any tips?
Normally I run a fuzz first (Fuzzrite) -->
Red Rooster -->
OD (HC or HBod) -->
Timmy (for clean boost) -->
TU-2 -->
DMemory Man -->
AMP
Red Rooster -->
OD (HC or HBod) -->
TU-2 -->
DMemory Man -->
AMP
New knowledge is the most valuable commodity on earth. The more truth we have to work with, the richer we become.
Kurt Vonnegut, Breakfast of Champions
Re: Tips to get fuzz to play nice with a Hot Cake (buffer)?
i just took a peek at the schemo, it doesn't look like there's a normal buffer in the hotcake..... it uses the inverting input on the op-amp as the clean bypass.... i don't really understand that! as i'm no electrical engineer..... your best bet is to do like red said and throw it in a looper pedal.....
- imguitardan
- SonicVI
- jetofuj
- imguitardan
I may be imagining it. I feel like the Fuzzrite sounds squishier (but it totally may be mind over matter).SonicVI wrote:The Hot Cake shouldn't have any effect on the fuzz if it's after the fuzz in the chain. In what way do you feel it's messing with the fuzz?
- edkoppel
It may have more to do with the volume you're running the fuzzrite at than the buffer in the hotcake?
yeah you could be hitting the chip in the hotcake pretty hard and your getting some compression and sag going on....
- joegagan
my dusty memory recalls a thread or two at aron's diy forum where ppl discussed the hotcake. pretty sure it is not true bypass.
it was designed by paul crowther , drummer from the band split enz, guitarist neil finn originally used with ac30s in that band.
ken fischer of trainwreck also helped crowther get more noticed in the US, as he had his mom pick up a hotcake for him while she was on vacation in new zealand in 94. ken wrote a good review in his column in vintage guitar and the rest, as the say, is stompbox history.
