Your favourite non-NKT275 Ge transistors for a fuzzface?
- superslidetail
Re: Your favourite non-NKT275 Ge transistors for a fuzzface?
This might be stating the obvious but you should invest in a breadboard and start the experimentation from there if you haven't already.
- Coolhand78
oh yeah man, i've got one but there are so many options out there I'm just looking to narrow down to a few that might be tried and true to find the ones (and gain ranges that i like)...!superslidetail wrote:This might be stating the obvious but you should invest in a breadboard and start the experimentation from there if you haven't already.
Also going to make one with sockets so I can easily test them as well...!
"Yorkshire isn't a place. Yorkshire is a state of mind." ~ Howard Moon
- superslidetail
I got a large range of values in resistors and capacitors plus sockets as well. I have a Fuzz face built by Venus that is socketed on just about every component on the board. It's pretty damn cool for experimentation.
- Bartioloxi
I really liked MP20A transistors. They are cheap, they have lots of volume without altering the 470 ohms resistor and they have low leakage overall
- Radiotron
The only real circuit change I do is op the 470R resistor to 1K, this brings out the highs and bumps up the output a bit, like taking away a blanket covering your speaker.
The rest is down to transistor selection.
I have narrowed it down to a pretty select range of gains/leakage combo’s I like and then make sure I have plenty of those to pick through.
Then is just a matter of sticking them in the test box and trying all the combinations, some just have that little bit extra, even when electronically they’re the same.
I like the BC108 or the BC209 for a non-germanium. Jim built me a really nice BC209 that absolutely screams and has a nice feel to it. The BC108 versions I have tried have a sweet spot, sort of a one trick pony, but that trick is so damn good time stands still.
Quite possibly a clone of the BC209 Captains Choice Head Buzz...fantastic si FF1bottlerocket wrote:Jim built me a really nice BC209 that absolutely screams and has a nice feel to it.
Users browsing this forum: Amazon [Bot] and 19 guests
