[LIKE ME, IT'S JUST TOO HOT] LuciferRising problem
- rootfifthoctave
I"ve not had it very long, played it a couple of times in the past two weeks, then today I plug it in and it's HEAVILY gated, to the point where barely any sound is getting through. Just sputtering out and dying. I tried it with battery, PSU, different guitars, same thing. The indicator LED is fine.
It's a hot, humid day here, but it's the UK, not Italy or California, so it's not deathly hot. I'm not having a problem with other germanium stomps. Could it just be that it's a hot, humid day? I'm worried because I was really digging it the other day and it cost a fair bit
I'd be grateful for any help/advice I can get!
Last edited by rootfifthoctave on Mon Jul 10, 2017 12:44 pm, edited 1 time in total.
Re: Help - Lucifer Rising suddenly sounds mis-bias'd?
What PSU were you using? these are positive ground so need isolated power supply, have you been using it with a battery or power supply for the last couple of weeks?
I'd contact Dave straight away and he'll make it right.
- rootfifthoctave
Oh, shit the bed I've had it plugged into my powerplant jr with everything else. I forgot this was the one fuzz I have that's +gnd. Have I fucked it? It's out of warranty by a couple of months. I feel so damn stupidinnerflight wrote:What PSU were you using? these are positive ground so need isolated power supply, have you been using it with a battery or power supply for the last couple of weeks?
- Yggdrazil
Plug it back with an isolated source; it should be fine...
Instagram:@Stonefly_effects
- rootfifthoctave
Tried with a good battery, it isn't fine. I don't know much about electronics but I have a multimeter and tested some continuity points. I'm not hopeful. It's probably time to send a grovelling email to somebody cleverer than me.Yggdrazil wrote:Plug it back with an isolated source; it should be fine...
Probably a good time for this emoji
- mplsaustin
I know my Lucy starts gets grumpy over 75F. Try putting it in the fridge for 10 minutes and try it again
I want it louder. Want power.
- rootfifthoctave
Now I feel even stupider. This was all that was wrong.mplsaustin wrote:I know my Lucy starts gets grumpy over 75F. Try putting it in the fridge for 10 minutes and try it again
Re: [LIKE ME, IT'S JUST TOO HOT] LuciferRising problem
The heat does have an effect on some fuzzes!
- windjamma
When my Brickbender came in the post i had the same problem. Popped it in the fridge for a bit, sorted. Tape echos are another thing i have found don't like warm humid weather.
Users browsing this forum: No registered users and 18 guests
