Boss OC-2 Ocatver Help
Hi all,
I have been using my Boss OC-2 Octaver (not the Octave version) and I am having trouble with the tracking on the low E string. There is a lot of dropping out, sputtering and skipping. Is this something that is inherent to the design or are there some settings that can help with this?
I have been trying different setting some worse than others but the tracking is still an issue. I have been staying on the neck pickup of my strat and playing single note runs. I have had to modify my playing a lot to make it sound good overall and I have gotten to the point where 90% of the octave tones are fine now. It is just the low E where I am still having a lot of trouble.
Any comments or suggestions are welcome. I have been thinking about selling it and trying a Foxrox Octron.
- chankgeez
Re: Boss OC-2 Ocatver Help
That seems about normal with any analog octave pedal. OC-2 still tracks better than most.
Try a little compression before it. You also may need to alter your playing technique slightly. Don't let the low E string ring out as much.
0
Thanks guys. Yes, I have had to clean up my technique to get things sounding right. I exchanged a couple messages with Dave Fox and sent me a short video and this also helped. I think I am going to sell the Boss and go with an Octron moving forward. I never thought about compression I am going to give that a go.
- chankgeez
As with Philip suggesting a bit of a boost, compression adds a little stability.
0
- SilverTightrope
Very normal with the Boss, part of it’s “charm”. Compression can help as mentioned, but it detracts a bit from the inherent fatness of the sound. I had the Octron, and although it tracks a little better, it’s not as fat/organic as the Boss.
~Actually I think Art lies in both directions - the broad strokes, big picture but on the other hand the minute examination of the apparently mundane. Seeing the whole world in a grain of sand, that kind of thing~ Peter Hammill
Thanks again for the help and suggestions. I am going to try some compression and see how that goes.
- chankgeez
Will do. It will probably be Wednesday before I am able to get to it.
I've found the low E guitar note range are hard for any octave pedal to easily track. I also find that backing off the tone knob helps the tracking be more stable. Compression is usually the best bet, overall.
This thread made me break these out today!
Users browsing this forum: No registered users and 7 guests
