Batteries in pedals
- welshchris
Re: Batteries in pedals
I pull them out when not in use.
I also put a bit of insulating tape over the 9v socket pins inside the pedal if I’m running the pedal on a gig board with PSU. Just always been a bit nervous of them moving in transit and then shorting out on metal case before or during a gig. Overkill I’m sure but once it got into my head..
... No I can't turn down
A standard 9V jack used for external power on a pedal isolates the +9V connection on a battery snap when a plug inserted. For the same reason that its impossible to drain your battery when using external power, its impossible to short to the case via the battery snap.welshchris wrote: ↑Tue May 28, 2019 7:10 pm I pull them out when not in use.
- jreeves47
I have my butler remove them and label them. They are stored in one of the guest bedrooms until needed, with the overflow being donated to a local charity.
- Bert Ohlsson
From a couple of years back
- batteri.png (252.74 KiB) Viewed 2281 times
- DAMbattery.jpg (16.78 KiB) Viewed 2281 times
- welshchris
That’s great to know :) had thought they were maybe just a parallel connection and didn’t want to risk anything.
Dr Tony Balls wrote: ↑Tue May 28, 2019 7:14 pmwelshchris wrote: ↑Tue May 28, 2019 7:10 pm I pull them out when not in use.
- mondo500
I had one leak in my Telenordia TA–24... was quite displeased. Fortunately only the battery snap was affected, but even the snaps are beautifully done on those pedals...
- PSQRCL
Definitely in the take the batteries out camp for me.
Had a D*A*M Sonic Titan in Starlight with battery leakage within. The Captain replaced it on the house though!
I've started going through my pedals and removing the batteries just in case.
- mam8dg
Yikes, I didn't know AAs were more prone to leakage. Need to check my Model AA today and remove the battery.
I normally don't take batteries out, though I should. I've seen some minor leakage, but nothing bad enough to necessitate replacing a battery snap.
migsmoon.bandcamp.com
Users browsing this forum: No registered users and 33 guests
