Any idea what trannies were used in the Ram Head?
I have a white big box with BC182Ls and had a PCB with BC239C.
What others were used -- and what runs had what trannies?
Any ideas?
PCB with BC239C.
Also, I've seen two different boards inside. Mine has a small perfboard with BC182Ls
Then I saw this one from 2006 with a big perf board inside...legit?
Ram Head Trannies and boards?
- Sage
Re: Ram Head Trannies and boards?
Here's my big box Ramhead from 2007 w/ perfboard and 4 BC239C's.
- happiass
Here's mine from 2008, its got BC239C's as well.
- Ram Head 2.jpg (261.75 KiB) Viewed 19850 times
- Ram Head.jpg (131.1 KiB) Viewed 19850 times
here's big box #20 from '06.... BC184L's and small stripboard.
hey dev... here's a link to #49 built in '06 with the larger stripboard.... i'd say that other one you posted is defo legit! i wonder when the change to the larger board took place?
http://stompboxes.co.uk/forum/viewtopic.php?f=6&t=4177
- DSC00007.jpg (267.02 KiB) Viewed 19841 times
- DSC00002.jpg (297.25 KiB) Viewed 19841 times
- DSC00003.jpg (349.36 KiB) Viewed 19841 times
- DSC00001.jpg (372 KiB) Viewed 19841 times
- skybone
- MMG
Did David ever make any Ram's Heads with 2N5133's? Thanks...
One or two I think?!?!
I can't recall what had what transistors in as such but I think the first few with the GGG PCB had BC549C's, the small strip boards where mainly all BC182L's. Then the small box Ram started out with BC239B's but I switched the BC239C's pretty soon after rolling with the B's. After I switched back to the big box and strip board it was 239C's all the way, with the exception of the occasional odd ball circuit.
- digdown2001
I have a white one and a green one, white with BC182L's and green with BC239C's. I'm curious, is there a general thought for the best version?? Or just slightly different flavours (the white one is listed as a copy of the 1976 circuit, the other 1975)??
I'm going to have to sell one of them, and I'm still not sure which one I prefer to be honest.......but I am leaning a little to the green beastie.....
Please don't suggest I play both and pick one that I feel sounds good, I've already leaned toward the green one, but I want to know if there is a general preference for one version over the other, and if so, why?? I guess I'm curious as to why the change in trannies moreso than any other reason....
Thanks in advance....
Steve
Steve
Nice Marmot.....
