MF-72 #001
Re: MF-72 #001
fucking epic time to be broke!!!
This thing looks righteous! I don't even know what to say...
- DucRyder
Re: Re:
Bump for the cap'n with another question below
DucRyder wrote:The Captain wrote:thanks for the description Dave! Riddle me this... Can you plug into the "Grease" input then have two effects (say a wah and phaser for example) run seperately and in parallel from each of the Grease outputs into the two Smoke inputs and then out the Smoke output to ones amp?DucRyder wrote:
I was thinking of two separate entities when I had the original idea though, like one big fuzz box that would cover as much ground as possible. I added the additional inputs/outputs for that reason. The user then has the ability to place them in the signal path where ever they see fit. Patching a wah and phaser between the two works pretty fine indeed.
"...Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba…" H.S.T.
- DucRyder
Thanks Captain... So this brings up all kinds of wild ideas of running effects in parrallel...
Re: MF-72 #001
Are all the auction units going to be the same colour same transistor set up?
Re: MF-72 #001
Missed that, thanks!stopmaykinsense wrote:1bottlerocket wrote:Are all the auction units going to be the same colour same transistor set up?From the first post!There a some subtle transistor variations and due to my smart naming of this big bastard I need to link to the pictures here for each said pedal. I've copied the write up here also, this being the first one an all.
- pigeontoe
- Mr. Min T. Fresh
I'm out.....................................................pigeontoe wrote:Just passed 1000 pounds
I have a big dick and I challenge you to swallow it or fight me strait up.
