WEM Rush Pep Box
- capricorn_1
WEM Rush Pep Box
Borrowed this off a friend! Will put a few more pics up shortly if people are interested, not sure which circuit it is exactly (but soon will!).
- P1010046.JPG (204.26 KiB) Viewed 4910 times
- charge
Re: WEM Rush Pep Box
Nice!!! Isn't that the fuzz Eno used/had his guitarists use on his early solo recordings?
Yeah, put up some clips!
Are you planning on making a clone? I'd be interested....
- superfuzz
Yep I'd like a little pep-up please
- capricorn_1
no i think that was probably the project V that is in pretty much the same case.charge wrote:Nice!!! Isn't that the fuzz Eno used/had his guitarists use on his early solo recordings?
I think this is a 2 transistor fuzz, just fired her up, quite trebly with lots of fizz and spit to decaying notes and a broad range of tones from the pep control.
will definitely do a couple of vids.
yeah i will be doing a short run at some point as the owner wants one so he doesn't have to use the original live.
- Nick
correct! do you have any pot codes on PepBox handy? :)capricorn_1 wrote:no i think that was probably the project V that is in pretty much the same case.
- capricorn_1
226nightraven wrote:correct! do you have any pot codes on PepBox handy? :)capricorn_1 wrote:no i think that was probably the project V that is in pretty much the same case.
it actually looks quite similar to Grahams here - viewtopic.php?f=6&t=2556&p=40947&hilit=226#p40947
- P1010047.JPG (197.92 KiB) Viewed 4868 times
- Nick
- Electric Warrior
- mjkk
- capricorn_1
yeah 2 x BC107mjkk wrote:Very cool Si trannies right?
Users browsing this forum: No registered users and 20 guests
