POST YOUR PEDALBOARD
- rootfifthoctave
- cajone5
Re: POST YOUR PEDALBOARD
Standard -- Fuzz Factory with 3-band EQ on Channel 1 and SHO on 2. Stock setup -- I picked it up for less than $100 so I couldn't pass it up. Eventually I'll use it to breadboard some things, I suspect, but I have to say a FF with 3-band EQ really can get a TON of sounds and I've been digging those settings a lot lately. Still have my other FF and will probably build a clone of inventobox (with 3-band EQ) one of these days so I can start using the thing to breadboard stuff.resynthesis wrote:Ah, an Inventobox! How's that set upif you don't mind me asking?
Timing has a lot to do with the outcome of a rain dance.
- resynthesis
That's a bargain
- anemochore
- Location: Outside of Suquamish at the bottem end of Hawkeye's trail next door to Nooshkum
- Snufkino
- Blues Bird
How do like your Broadcast pedal? Does it live up to the hype?cajone5 wrote:Standard -- Fuzz Factory with 3-band EQ on Channel 1 and SHO on 2. Stock setup -- I picked it up for less than $100 so I couldn't pass it up. Eventually I'll use it to breadboard some things, I suspect, but I have to say a FF with 3-band EQ really can get a TON of sounds and I've been digging those settings a lot lately. Still have my other FF and will probably build a clone of inventobox (with 3-band EQ) one of these days so I can start using the thing to breadboard stuff.resynthesis wrote:Ah, an Inventobox! How's that set upif you don't mind me asking?
- norhyme
Users browsing this forum: No registered users and 12 guests
