Show off your builds!
pizzanoise
Re: Show off your builds!
Post by pizzanoise »
Tonebender MKII - feat. Telefunken OC602 spezial - amazing choice, really wow :)
Tonebender MK II-s.jpg (177.6 KiB) Viewed 4303 times
pizzanoise
Selmer buzzaround clone - more buzz than fuzz, usefull sometimes...
Selmer Buzztone-s.jpg (172.65 KiB) Viewed 4216 times
simonm
Post by simonm »
pizzanoise wrote:Selmer buzzaround clone - more buzz than fuzz, usefull sometimes...
very nice builds! those tag board /eyelet things you use are cool. I like the Buzztone in theory but haven't used my clone much...
pizzanoise
Thank you very Simon, I build these tags from the scratch.
platine ready-s.jpg (108.07 KiB) Viewed 4162 times
platine nieten-s.jpg (109.7 KiB) Viewed 4162 times
platine bestücken-s.jpg (329.6 KiB) Viewed 4162 times
platine bohren-1-s.jpg (138.32 KiB) Viewed 4162 times
Post by daCod »
Brutalist pair. Bare is standard. Trippin Turtle is COD KVLT version :badteeth:
https://i.imgur.com/OxhWRNP.jpg
vanguard
Post by vanguard »
MK1.5 and Rangemaster dual unit.
https://blackstrapelectrik.com/
Has anyone seen an Englishman called Gavin?
Zuff-1A
Post by Zuff-1A »
Good point :tu:
I'll bet this thing sounds incredible!
Dr Tony Balls
Post by Dr Tony Balls »
Just finished up a little re-work job. This amp started life as a Fender PA 135, and at some point was converted into another amp by someone. Their idea was apparently that it'd be half 2203, half AB165 but thats not a real possibility and the implementation was poor regardless so it came to me to turn the ship around. Owner decided he really just wanted something plexi-like so we went in that direction, but expanded it to take advantage of one of the extra preamp tube sockets (it had six). Its basically a combined amp that has a 1987/1959 (lead) preamp as well as a JTM45/1986/1992 (bass) preamp. I was trying to utilize the holes that already existed in the chassis, so I went with one linked input for the whole thing, with blend-able volume controls for each channel. LarMar master volume per the customer's request. Its not the prettiest guts ive ever put forth but was trying to maximize use of what was already there.
Dr Tony Balls
Nothing terribly new here. Quick analog delay build with slammage.
jreeves47
Post by jreeves47 »
that delay looks excellent
