Krzy Wski aka Hałas Efektors
- resynthesis
Re: Krzy Wski aka Hałas Efektors
Very nice indeed.
BTW How are those PCBs?
- resynthesis
Ace, ta
- kosta
That bass clip sounds goooooooood. Dang!
I had predrilled enclosure for an old project and booster board ready, so I was forced to build 3 knob version with led and dc jack
Except range control and boost volume, you have bias - full clockwise is "standard" voltage, that you can lower. The difference is sublte, but changes the feel indeed - from open to more compressed/fatter signal.
No corners cut, including NOS black glass OC43.
$olded
$olded
- black_booster_top.jpg (131.65 KiB) Viewed 4712 times
- black_booster_guts.jpg (198.95 KiB) Viewed 4712 times
This turned really great, imo. Bass lines were recorded with Rick into Hiwatt with black drive or/and black booster in between
https://bitchcraftband.bandcamp.com/
- Lee
Looks awesome wish I had the monies could use one
Your builds are always top notch wish you built more like you use too
Thanks Lee It's simply too cheap to be true
Of course you can always send it back, if you don't like it (minus shipping fees).
I guess that everybody is fed up with booster, but here it goes
Black Yak - rangie with range, bias and boost controls + 2 switchable transistors: OC72 for cleaner tones and high gain OC43. My aim was to create really flexible booster that you can use with different guitars/pedals/amps. And of course, I really dig 2 board construction
Out of stock
Out of stock
- black_yak_1_top_1.jpg (354.05 KiB) Viewed 4202 times
- black_yak_1_guts_2.jpg (495.65 KiB) Viewed 4202 times
Users browsing this forum: No registered users and 20 guests
