Early Boss CE-2 LED works, but no modulation
- Hagstrom71
Re: Early Boss CE-2 LED works, but no modulation
I had a tech take a look at my CE-2 and turns out it was a grounding issue with one of the pots that was killing the chorus fx.
A bit embarrassed I wasn't able to figure that out, but at least it's back in working condition. Thanks for all the troubleshooting suggestions.
hah! had that same sort of prob with a TS-9! but there the short took out one of the divider resistors in the power supply for the 4.5V bias supply...
- Spook
...And i had it today in a Double sound wah, one of the wires to the pot was not cut at the lug, and touching the pot. Made it work backwards and other wierd stuff,
i was about to go batsh*t crazy before i figured out what was wrong .
Don't be. I have an old analog delay that hasn't ever worked right. If I open it up, it works fine, but as soon as I put the case back together no delay.Hagstrom71 wrote: ↑Sat May 04, 2019 6:29 pm I had a tech take a look at my CE-2 and turns out it was a grounding issue with one of the pots that was killing the chorus fx.
It's been sitting in a box for years, but I took it out the other day to look at it and it turns out the input jack is grounding out on the case, Doh!
- Hagstrom71
That's similar to what mine was doing! the pots were grounding out on the case.
Hi gang,
I have a japanese made flanger pedal that doesn't work. LED does light up but all I get is the bypass signal (zero effect whatsoever).
Should I measure the opamp voltage too? Does it include the MN300x chip voltage and MNxxxx clock driver?
Thanks very much!
Thanks very much!
OK so I went ahead a took some voltages on the RC4558P chip.
(EDIT: there's 2 of them but one is an LFO chip that seem to work ok, as pin 3 and 7 provide varying voltages from 2 to 7V)
Here's what I got on the "non LFO" 4558 chip:
Pin 1: can't get measurement, starts at around 3V then slowly goes down and stabilizes at around 0.4V
Pin 2: same
Pin 3: 4.9V
Pin 4: 0V
Pin 5: 4.9V
Pin 6: 8.9V
Pin 7: 8.7V
Pin 8: 8.9V
It looks fishy to me but I honestly don't know squat about ICs.
Is it good ?
Or should I replace it?
Or should I look for bad components next to it?
Or should I look elsewhere?
Thanks very much for the answer.
Pin 2: same
Pin 3: 4.9V
Pin 4: 0V
Pin 5: 4.9V
Pin 6: 8.9V
Pin 7: 8.7V
Pin 8: 8.9V
Is it good ?
Last edited by rileyismycopilot on Tue Jun 11, 2019 12:31 am, edited 1 time in total.
(BTW I wish I could open a new thread but as a new member I can not do that, so I'm hijacking this thread as the original poster asked about a solving problems on an old chorus which is quite similar to my old flanger).
Yup, that looks bad but do you have a name for this mystery flanger so I can see a schematic? Could be something around the chip causing it.
Thanks for the answer!
The Flanger in question is a "Guyatone PS004". Please let me know if you find something.
Users browsing this forum: No registered users and 26 guests
