Got my Super Bee and it sounds great! What is this though?
Germanium fuzz tones for old school heavy minds.
Jazzandmetal?
Post by Jazzandmetal? »
Is this some sort of ground? I have had a few and seen a bunch of DAM pedals and haven't seen this on one that I can recall.
Thanks for any help.
fuzz.head69
Re: Got my Super Bee and it sounds great! What is this though?
Post by fuzz.head69 »
thats a ground point, because the pedal uses cliff jacks the enclosure doesn't earth on the jacks. To get around this dave uses the earthing point as seen which is a quality way of ensuring the circuit stays noise free and earthed correctly.
The Captain
Post by The Captain »
Bingo! Well said, sir :badteeth:
devnulljp
Post by devnulljp »
Sorry to hijack, but is that why my big muff tone wicker is so bloody noisy?
It's got those plastic jack mounts...
It looks like it's supposed to have some kind of a ground pin (top left) but I'm not convinced...
devnulljp
Post by devnulljp »
Sickle wrote:What the hell is that, some kind of spring pressing off it against the case?
:banger:
Pretty much..."if it's worth doing, it's worth doing in the cheapest shoddiest manner possible" apparently.
Jazzandmetal?
fuzz.head69 wrote:thats a ground point, because the pedal uses cliff jacks the enclosure doesn't earth on the jacks. To get around this dave uses the earthing point as seen which is a quality way of ensuring the circuit stays noise free and earthed correctly.
I had another bee that I borrowed from my friend Ross and it didn't have this. Do others have it as well? They have the same jacks no?
The Captain
We switched back to using OMEG pots. The pots in question have plastic housings so are also insulated from the enclosure, hence us using the rivet and solder lug as grounding. The Alpha pots we used to use had metal casings so we could ground the circuit there.
Jazzandmetal?
Thank you for taking the time to answer Dave.
I am very curious about things so I appreciate you taking the time.
This pedal sounds fantastic. When you dial the gain back, it gets an almost overdrive thing going on. I noticed that with the #13 Super Bee I borrowed as well. You almost need 2 bees, one for fuzz and the other for OD.
Probably one of the most versatile pedals I have owned. It will indeed go down as a classic like the Red Rooster and Titan. :hihi:
fuzz.head69
devnulljp wrote:Sorry to hijack, but is that why my big muff tone wicker is so bloody noisy?
To be fair to EH, there pedals are bloody cheap. that spring earth works well for Catalinbread and a few others, however the fault with the wicker is the poor componentry and high gain circuit, mine was so noisy i had to return it to the shop. The D*A*M way of doing things is the most reliable and least noisy. takes more time though, hence why its not found in many pedals.
1bottlerocket
Post by 1bottlerocket »
Whew, that SB is one fine looking pedal. I can hardly wait to run one in a side-by-side with my '66
Users browsing this forum: No registered users and 14 guests
