MK11 works, but wont work bypassed
Hello, I built up a few MK11's and two of them work, but will not work when bypassed, only works with the fuzz on. I have never had this problem before, and am hoping someone will have an idea of what I am doing wrong.
- Fuzzz
Re: MK11 works, but wont work bypassed
could be the wires are reversed on one side of the switch? Or a faulty switch maybe.. I would check the switch wiring and continuity as I have had new switches fail on a build before..
Logic should not interfere with determination
Thanx for the reply, but I think it has something to do with the jacks. I say this because, two pedals are doing the same thing. I am using the plastic Cliff type jacks, and the pedal didnt work until I connected both sides of the jack. Does this mean anything to you?
By the way, I am a big fan of all the different pedals and mini amps you have made. Some of the wiring you do is brilliant!
- Fuzzz
Sadly I am not the mighty Steve of Pigdog - just a lucky owner of one of his pedals! Hopefully one day my wiring will look like his, but unfortunately I doubt I will!
not sure what you mean about connecting both sides of the jacks, but if its working on effect and not bypass, I think it would be more likely that its the switch... Maybe one of the veteran builders will have more advice..
Pics would help the troubleshooting by a mile.
- peps1
Grounding shouldn't affect the bypass.
- peps1
Thanx for all the help, will post pictures when I get home.
Users browsing this forum: Semrush [Bot] and 5 guests
