Pedal request. Sandalone Silicon side from The Coop
- erer
the silicon side on the coop fucking slays. it shoud be its own pedal! that is all.
- anemochore
Re: Pedal request. Sandalone Silicon side from The Coop
- Funky Druid
The Captain wrote:Same shit different box. Basically I was trying out using a Hammond made enclosure again, like on the first Roosters I made. I changed the sub-heading to 'amplitude booster' in case I continue with the enclosure type so it frees me up to make silicon versions as and when requested/required.
I started the numbering from #000 on these due to the above and also that I would be making these units myself. The only circuit change on these units that went to DSM was the addition of 470 ohm resistor tied on the boost pot, so that when the boost control is zero'd there is still a slight signal pass. All had Mullard OC82DM's and were mid to high gain types.
Just ask Captain for Si version. Captain seems to be in mood for custom jobs recently
- erer
I would like to try that out also, I wonder if it is like the boost side on the Pigdog Heavy Load? that was the best boost I ever had
- mam8dg
I would love the silicon side of the chicken coop, I'd definitely be in for one!
migsmoon.bandcamp.com
tis nothing like the heavy load. not near as much honky midrange cut/bite/bleed-your-ears. both epic boosts in their own rite.
coop is a monster. i should know
Si Roosters for da MASSES !!!!
^ good to know, now I want heavy load boost as a stand alone as well
- stella_blues
Is the silicon Coop similar to the Blind Mary JHS treble booster ?
