Amp Issue
- thebends9
Amp Issue
Have a lead on an older amp with a buzzing issue; Guy states the following:
I can best describe it as a low end buzz that changes pitch with the notes you're playing. mostly on lower notes but not the same weird buzzing sound that a blown speaker gives off.
Any idea what this could be?
The Captain wrote: If you find a 'fake' transistor in a D*A*M pedal I will literally eat my own dick. Confident I am.
Re: Amp Issue
filter caps...
- thebends9
Re: Amp Issue
Thats what I was afraid of. He thought it might be his tubes
Re: Amp Issue
I get this occasionally on my 1970 VibroChamp, a buzzy, distorted sound when you're fretting the bass strings, especially the bottom E, even though I've replaced the filter caps. Bugs the shit out of me because it doesn't happen all the time.
- waveclipper
Re: Amp Issue
Filter caps most likely but still might be a voice coil rub, dodgy tube or possibly parastics? I've no doubt any decent tech with an oscilloscope could have that sorted very fast. Fear not - filter caps would be a cheaper fix than decent tubes!
You might be able to stiffen up the power supply of your Vibrchamp just enough to get rid of that horseyboy? Maybe just increasing the first filter cap to 22uF might be all that it takes - shouldn't make any major tonal differences and a 5Y3GT should be able to handle it no bother.HorseyBoy wrote:I get this occasionally on my 1970 VibroChamp, a buzzy, distorted sound when you're fretting the bass strings, especially the bottom E, even though I've replaced the filter caps. Bugs the shit out of me because it doesn't happen all the time.
Re: Amp Issue
Did you change the bypass caps as well? I had a 1970 Champ that developed this fizzy buzzing that would ride on top of the notes and changing out the waxy bypass caps fixed it.HorseyBoy wrote:I get this occasionally on my 1970 VibroChamp, a buzzy, distorted sound when you're fretting the bass strings, especially the bottom E, even though I've replaced the filter caps. Bugs the shit out of me because it doesn't happen all the time.
- charge
Re: Amp Issue
Sounds like the issue I had with my 67 Vibro Champ. A new speaker resolved it.
- PlumCrazy
Re: Amp Issue
And replacing the filter on a VC is a pain in the ass. The speaker on my 74 sucked big time.HorseyBoy wrote:I get this occasionally on my 1970 VibroChamp, a buzzy, distorted sound when you're fretting the bass strings, especially the bottom E, even though I've replaced the filter caps. Bugs the shit out of me because it doesn't happen all the time.
http://www.plumcrazyfx.com
Re: Amp Issue
Thanks for the advice, guys. I'll crack it open and check it out on the weekend.
It did occur to me that it might be the speaker, but the speaker was replaced (with a Jensen P8R) before I got the amp and I figured it would be okay. I'll try running it through a cab to make sure. But I might start hunting for a vintage replacement anyway, just to be sure.
Here's a pic of the guts last time I worked on it:
(Click through for a full-size shot.)
Replaced the cap can, removed the “death cap”, replaced the electrolytic caps with the Spragues and tone of the resistors (the 460/1 watt). If anyone spots a dodgy solder joint, let me know!
- waveclipper
Re: Amp Issue
Either of you got things sorted yet?
I'm thinking you might need a buddy with an oscilloscope at this stage Horsey?
