Sola Sound Tone Bender MKI
- Gemma Thrush
Re: Sola Sound Tone Bender MKI
Can any of the 4 variants do this?
Yep . I could ask Steve how and why but I get the feeling it’s easier getting information from a spy .
Wow! Fuck, that is superb!
I'd say any of them... with the right amp settings.
- Gemma Thrush
excellent.
Sounds ace man, love it when the attack is right down at the beginning
Btw has anyone found rubber stoppers/feet that are higher than the nobbly bits moulded on the bottom of the case, these slip around like fuck
Yeah, love it set to about 1 - 2 on Attack, Level set to give a slight volume boost.innerflight wrote: ↑Fri May 18, 2018 5:07 pm Sounds ace man, love it when the attack is right down at the beginning
My dimples have a worn a bit from skimming about rehearsal room floor.
- pepperco
Cool. Further proof that everything does NOT need to be on 10 to sound perfect.
- fendersilver
Here are two good options to consider to help keep pedal from slipping out from under foot.
1. https://www.grainger.com/category/rubbe ... g%2FN-188k
Rubber Sheets, Strips, and Rolls
This natural gum rubber strip is abrasion-resistant, tear-resistant, and impact-resistant. It offers superior adhesion
to metal, and is suitable for electrical insulation. It features a smooth finish and plain backing. Commercial grade.
This neoprene rubber strip is engineered to resist abrasion and impact. It features an adhesive
backing and offers superior adhesion to metal. Choose from commercial grade and high grade.
Select Durometer 1/32" 2" 3 ft. Black 170 Multiple Items $4.40
Select Durometer 1/16" 2" 3 ft. Black 170 Multiple Items $4.40
Select Durometer 1/8" 2" 3 ft. Black 170 Multiple Items $6.90
2. https://www.grommets.co.uk/products/gro ... -grommets/
Open/Cable Type Rubber Grommets - *Adhesive not included.
Part Number: G10-R175-16-143
a (mm] b (mm) c (mm] d (mm) e (mm)
(17.5) (1.6) (14.3) (6.5) (21.5)
_______________________________________________________________________________________________________________________________________
“Part of the journey in life is slipping and falling along the way; in these times true friends are the ones who pick you up and dust you off.”
