DAM MKII Attack pot problem
- Chi-LA
Hi all - working on the rehab of #110 - all working except the attack pot seems to be stuck at full, ie no gain attenuation. The wiring looks fine - what could the problem be?
Before/after pics below
- Chi-LA
Re: DAM MKII Attack pot problem
Pics…
- AFE9E114-A904-4871-B68E-FFD0F35D315D.jpeg (1.41 MiB) Viewed 1014 times
- B4FC023D-955C-474B-BB3D-5BEAB2CF4BE5.jpeg (1.13 MiB) Viewed 1014 times
- Tin Shack King
Wow! Is that the original box, and if so, how did you remove all the gunk?
Replace the pot with a new one that doesn't look like it went down with the Titanic?
- Chi-LA
I used a steel bristle brush to remove all traces of oxidation then spayed with matte silver rust cap. But had to replace both pots and the switch. Ready to finish it up as soon as I suss out the attack pot…
- Chi-LA
Pots are brand new original type alphas…
make sure you have a solid ground connection for the pot, and no breaks in the copper strips... test continuity of the leads to the pot
- Tin Shack King
Great job on the restoration! It should be a great pedal when you're finished.
- squarewave
Someone must have really hated that thing
- Spook
Does it work ok when its just the circuit, not insde the box ?
