Needed replacement input jack for Maxon D&S V1
Freed
Post by Freed »
My Maxon D&S V1 (with the Sustain T knob) the input jack has exploded…problem I found in getting a replacement is that this jack has a smaller diameter around and I don’t want to ream the hole for a modern panel jack.
Anyone know where I can get a suitable replacement or have an extra?
Thanks
moose
Re: Needed replacement input jack for Maxon D&S V1
Post by moose »
Can you measure the hole? The Lumberg jacks are made for a 9mm hole rather than the usual 10mm for Switchcraft etc.
simonm
Post by simonm »
is it this? Lumberg KLBPS 3 Jack Socket 6.35mm Chassis Mount 3 Pole Stereo with Break
Japanese part, maybe available from tubesandmore or mouser?
https://www.tubesandmore.com/products/1 ... en-circuit - not exactly the same but same 9mm bushing
simonm
Post by simonm »
double post, doh!
moose
Post by moose »
Just checked the data sheets and they're both 9mm.
Farnell have them here:
https://ie.farnell.com/lumberg/klbp-3/s ... n-Test1573
