Wow! This and the Tele look fantastic.
What is on your workbench Tinkerers?
- squarewave
Fanks mate. Just started a Les Paul build, took a bit of weight out of it.
moving to new page as i still needs the helpdaCod wrote: ↑Thu Jan 13, 2022 10:31 pm push pull pot question. these cool looking Gibson ppat-520 potentiometers...
for coil splitting, run series wire to one lug and the other lug to ground?
anyone have experience with these pots? they look cleaner to me than your usual stacked terminals tower looking design.
- skelt101
You have it right, Cody. Check out the diagram here:daCod wrote: ↑Fri Jan 14, 2022 4:26 pmmoving to new page as i still needs the helpdaCod wrote: ↑Thu Jan 13, 2022 10:31 pm push pull pot question. these cool looking Gibson ppat-520 potentiometers...
https://www.stewmac.com/video-and-idea ... gram-spst/
Much easier to work with than the tiny terminals on most push/pulls if you don’t need DPDT functionality. Good construction too.
skelt101 wrote: ↑Fri Jan 14, 2022 6:30 pm You have it right, Cody. Check out the diagram here:
thanks! i'm not quite sure how i missed them on the stewmac site
they're cheaper on the site too compared to the gibson branded ones at my local shop - like half the price!
time to place an order.
master tone bypass via push/pull bridge tone pot diagram just finished.... because who actually works when they're at work
in my head it works perfectly. but in real life, will it actually work?
EDIT: sorted. It good
I build super duper sounding super duper. It’s super. Time to duck up the enclosure and swap out them white washers
I realized I soldered the current limiting resistor in the wrong position on the daughter-board
and try as I may I could not get it back in position from the underside. So my derp derp is front and center for all to see.
i give you daCOD KVLT Serper Derper
HELLYEAH!
Is that your first pedal?
narp. first was that old weber rangemaster kit from forever ago.
then a few BYOC kits. and i did up two GCI brutalist's a few years back.
Ahhh tight. My first kit was me in a Radio Shack taking a stab at a Super Hard On, and while I certainly did NOT make a Super Hard On, I made something that worked enough to keep going. I'll hit my 1000th pedal at some time end of this year or early next...not sure what to do to celebrate it hahaha.
Users browsing this forum: No registered users and 11 guests
