WTF happened to this guitar?
How could a control and pickup cavity get so burnt? Looks like someone plugged straight into a mains socket! The bridge pickup seems ok, just the neck pup cavity is burned up. Could this happen if you plugged into your amp speaker output?
- 15D65355-5A32-465B-9937-19C538AB02D8.jpeg (126.36 KiB) Viewed 2808 times
Re: WTF happened to this guitar?
Whatever it was it looks like it would kill you. Looks like it has had mains power from the amp through it
Looks like someone used it as a bong.
- anemochore
Could be. Looks like it got very hot very quickly. No damage to the outside of the guitar so it wasn’t set on fire Hendrix style. Innards are toast though and lots of scorching around the input.
Could a bad earth on an amp do this? Scary if so.
- get_with_it
- Sola Sound London
I once had a microphone returned to Macaris 'not working ' ' no sound '
When they showed me the lead i saw they had taken the jack plug off and wired a mains plug on the end then plugged it into the wall !
Lucky to be alive
still not sure where they thought the sound was going to come from !
Maybe same customer had a guitar ????
Lucky to be alive
- Bert Ohlsson
- so&so
^ hahhahahaha
Users browsing this forum: No registered users and 18 guests
