Some Jordan Bosstone information
sir h c
Post by sir h c »
Hope to get pictures up soon, but don't have a correct card reader at home. I have 5 different Bosstones (and a Mahoney reissue), 2 Alhambras, one Pasadena, one Sho-Sound Nashville, and one Music City Mfg. Co. Nashville.
So it looks like only the early Alhambra version has 2 NPN transistors, the change to an NPN into a PNP occurred before the move ot Pasadena. Here is the trasistor list for each:
Alhambra (early green board both sides):
2N3393, MPS6513 (and a different configuration)
Alhambra later:
MPS5006, SPS5007-2
Pasadena:
2N5223, SPS5007-2
Sho-Sound:
2N3565, M924/95232
Music City Mfg. Co.:
MPS6513, 2N4249
So they are all over the place, and the two from Nashville look to be similar PCBs and all but the ones in California are not similar other than the case. It is a very interesting pedal.
sir h c
Post by sir h c »
Sickle wrote:Which one is hairiest? Hey Chris, did you see the Rogue Fuzz I picked up last month?
The initial Alhambra with two NPN transisotrs is the most biting. The change to a PNP transistor seems to have been to get it from the edge of oscillation and tame it some.
Saw the Rogue, it looks interesting, Bart thought it might have some connection to the Hohner Tri Dirty Booster, as the case has a similar look and setup.
sir h c
Re: Some Jordan Bosstone information
Post by sir h c »
Works for me, but in the end there will be some good pictures that might want to go to the other section. They all look the same from the front, but the back and guts help you tell them all apart.
sir h c
Post by sir h c »
Here are shots, your choice where they should go.
nashville bosstones comp side.JPG (911.35 KiB) Viewed 8329 times
cali bosstones trace side.JPG (894.67 KiB) Viewed 8329 times
cali bosstones comp side.JPG (849.94 KiB) Viewed 8329 times
all bosstones inside.JPG (833.88 KiB) Viewed 8329 times
all bosstones back.JPG (821.63 KiB) Viewed 8329 times
all bosstones.JPG (927.63 KiB) Viewed 8329 times
sir h c
Post by sir h c »
and a last shot.
nashville bosstones trace side.JPG (890.13 KiB) Viewed 8328 times
edkoppel
Been liked: 2 times
Post by edkoppel »
my sho-bud bosstone has different tranny's
a TS 3564 (ITT)? and another one that is totally blank but is green on the top and has green, blue and white lines on the back.
I'll post pics tonight when i get home from work.
until then I found an thread on these from the old forum
http://dam.10.forumer.com/viewtopic.php ... sc&start=0
here's a pic from that thread (and one I have never seen before!)
Creepyfingers
Post by Creepyfingers »
Great pics!
jerms
Post by jerms »
here's my three vintage ones.... i've got a mahoney too. the alhambra one is quite biting and a bit thin like a fuzzrite.... the pasadena one sounds awesome nice and fat but with a great high end grind... the music city one is a bit darker but maybe the most saturated, the mahoney sounds identical to this music city one. mahoney knows what he's doing!! not enough room for the closups.... see next post
jerms
Post by jerms »
close ups!
sir h c
Post by sir h c »
Great shots! The Alhambra (early) ones seem to have one less resistor than the others, not sure if it is one fewer cap also, but could be.
I will have to do a bunch of shots of the Creator and Vibrasonic next...
