Show off your builds!
Re: Show off your builds!
Data dump.
All red Super Black:
Moon Unit delay & verb:
BF-15 combo. 2 x EL84, 15 watt amp with preamp in the 60's Fender vein. Lots of clean, lots of chime, and grit if you wanna crank it. 1x12 combo with a Jensen C12N. Added post-phase inverter master volume to keep it chill when needed:
BF-15+ combo. Really very similar amp to the one posted above but with a tip in the other direction. No master volume, but an added and switchable Rangemaster/Ballsmaster style boost to the front end. Plays the same as if you had a RM pedal or amp-top unit in front of the input, but all internal. Transistor is a Soviet MЛ38a.
So. Fekkin. Gnar.
- squarewave
- Radiotron
That's some amazing work there Tony! Absolutely love the built in rangemaster!
THANKS!
Voomp!
This had been a wall hanger in a bar or venue for years and was covered in crud and falling apart. I only hung on to it because of the ‘Okay Hot-Shot Okay’ artwork.
70s Jedson pickup, 70s Japanese bridge, 70s Shaftesbury knobs, 90s Hohner neck bolted to a reclaimed pine centre block. It’s crude and rude but plays and sounds ace.
- Radiotron
Beautiful work as always!!
One tube reverb?
One tube reverb?
Yup. Bit more subtle than the Fender standard but does the job well enough for most needs.
Users browsing this forum: Bing [Bot] and 6 guests
