Validation build of the DEFX Definitphase. This is a clone of the Prophecysound Infinitphase. Many thanks to Mike Both (again!) on this build, he fed me a ton of info. This is a fully loaded build, complete with;
- Sample/Hold
- Stereo output
- Footswitch LFO rate doubler
- Footswitch 4/8 stage select
- Expression pedal input jacks for Rate, Depth, and Range.
- Expression pedal input jack for Phase Center, which allows for direct phase control
The only major change we've made is to replace the quad set of red LED's for the LDR's, with a single 10mm green LED. We stole that page from the Spaceman phaser. Hence the name "Definitphase", 'cuz it'll be the last phaser you'll ever need. Needless to say, it sounds awesome. :!!!:
http://i.imgur.com/JvCB0mr.gifv
