Red Rooster Power Supply?
yomaha
Post by yomaha » Fri Aug 05, 2011 6:49 pm
Hello,
Does anyone have any recommendations for a good power supply for the Red Rooster. I bought mine in 2008, and f'n love it, but it chomps batteries and the amount of fuzz drops off pretty quick once the 9v gets low.
thanks in advance,
K$
South Louisiana
devnulljp
Post by devnulljp » Fri Aug 05, 2011 7:46 pm
Shouldn't be using batteries that quickly -- are you unplugging when not in use? Think I've had the same battery in mine for a year.
Works fine off a onespot/PP2 type power supply though.
(I'd be kinda worried if it was producing fuzz in the first place seeing as it's a treble booster :hihi: )
jetofuj
Post by jetofuj » Fri Aug 05, 2011 7:54 pm
I might be wrong, but isn't it +9V in opposite to -9V (like most pedals)?
devnulljp
Post by devnulljp » Fri Aug 05, 2011 9:03 pm
I think so, so it'll work as long as you don't daisy chain it.
PP2+ comes with a reverse polarity adapter too.
Funky Druid
Re: Red Rooster Power Supply?
Post by Funky Druid » Fri Aug 05, 2011 9:05 pm
What trannie has this Rooster?
yomaha
Post by yomaha » Fri Aug 05, 2011 9:41 pm
Funky Druid wrote:What trannie has this Rooster?
John5?
King Cactus Crusher
Post by King Cactus Crusher » Fri Aug 05, 2011 9:48 pm
It will go through more batteries if it's one of the RRs with an LED but it shouldn't eat through them like a delay or anything.
If your RR is from 2008 it probably has a NPN transistor, which means you can use a regular, negative-ground power supply and daisy chain if you want to.
The "chicken head" ones without an LED and the newer ones are PNP (+ ground) so they can cause problems when daisy chaining.
yomaha
Post by yomaha » Fri Aug 05, 2011 9:52 pm
thx for the reply. Honestly, I usually don't unplug it entirely from the signal chain when I'm done (lazy)...which I agree drains it faster. I heard good things about the onespot. I'll try that now that I know it's +9 and PP2+ has a reverse polarity adapter. That's the info I needed.
And oh yeah - that's true, it's not a fuzz...my technical prowess rears its beastly head again!
Thanks,
Yomaha
yomaha
Post by yomaha » Fri Aug 05, 2011 9:55 pm
[quote=The "chicken head" ones without an LED and the newer ones are PNP (+ ground) so they can cause problems when daisy chaining.[/quote]
I just saw this message. Mine has the LED and the round knobs (no chicken heads).
:headbanger:
stratguy23
Post by stratguy23 » Tue Sep 20, 2011 5:28 am
Not to thread jack, but I just got a brand new Red Rooster from Downstroke. I really like it so far, but I don't wanna blow it up, so should I use the reverse polarity cable or a regular one? Thanks!
