Master Volume in a Rooster?
hyeronimusss
Post by hyeronimusss » Wed Sep 21, 2011 3:32 pm
Love my rr with maximum boost :crackjam:
this might seem quite funny for a booster, but I don't need a great volume boost, I'd rather keep that sound around unity level
I'm thinking about adding a master volume to the circuit
Would that be a crime?
Funky Druid
Post by Funky Druid » Wed Sep 21, 2011 3:45 pm
maybe You should build another treble booster with added master volume instead moding RR?
tigerdriver
Post by tigerdriver » Wed Sep 21, 2011 4:21 pm
Would that not just make it sound different anyway?
I would think the result would be less overdrive and more noise, in which case you might as well just turn the Rooster down.
hyeronimusss
Post by hyeronimusss » Wed Sep 21, 2011 4:33 pm
:hmm:
Cado
Post by Cado » Wed Sep 21, 2011 5:17 pm
tigerdriver wrote:Would that not just make it sound different anyway?
I think it would function more like the the Level knob on other fuzzes, affecting gain somewhat as it is lowered but would enable the user to get more dirt at unity level. I'd be able to get more use out of my Rooster this way. An internal trimmer would work just as well.
Creepyfingers
Re: Master Volume in a Rooster?
Post by Creepyfingers » Wed Sep 21, 2011 5:30 pm
It's a booster. The sound you are hearing that you like is the preamp of your amplifier being overdriven by a loud signal. Its not happening in the pedal internally. Its a combination of the pedal and amp. The "boost" knob IS a volume control. You would just be adding a volume control after a volume control. Turning a booster down to unity gain = no boost=no fuzz/distortion.
--Brad
devnulljp
Post by devnulljp » Wed Sep 21, 2011 5:38 pm
Listen to what Brad says.
Get an attenuator/powersoak that goes after the power amp and before your speakers.
Otherwise you're wasting your time and destroying your pedal.
I have a Ho attenuator on my AC30, the rooster pushes it into overdrive, the attenuator saves my ears.
hyeronimusss
Post by hyeronimusss » Wed Sep 21, 2011 5:41 pm
Creepyfingers wrote:It's a booster. The sound you are hearing that you like is the preamp of your amplifier being overdriven by a loud signal. Its not happening in the pedal internally. Its a combination of the pedal and amp. The "boost" knob IS a volume control. You would just be adding a volume control after a volume control. Turning a booster down to unity gain = no boost=no fuzz/distortion.
--Brad
I'm not competent enough to argue (infact, I'm quite ignorant on technical stuff, and on other things too)
But in my experience, if I use another pedal after the mighty Rooster (for example a Lo Driver with the volume dimed), I can get a fantastic crunchy sound at unity level - problem is that a) Lo Driver colors the sound b) I have to use it for other purposes at a different setting
Creepyfingers
Post by Creepyfingers » Wed Sep 21, 2011 6:20 pm
--Brad
The Rooster will overdrive anything placed after it. You're just substituting the Lo Driver for your amp. What you are hearing is not your amps preamp distorting.
DucRyder
Post by DucRyder » Wed Sep 21, 2011 6:32 pm
Brad of course is totally correct. That being said I think maybe hyperonimusss would like two boosters in series one to overdrive the other and that to drive the amp. Buy another booster and link 'em up maybe? Get a custom build from one of the builders here?
"...Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba…" H.S.T.
