Current Roosters Trannies?
jerms
Re: Current Roosters Trannies?
Post by jerms » Tue Sep 06, 2016 8:51 pm
AC128 FTW!!! mines acquiring a nice patina.....
fenderbender4
Post by fenderbender4 » Sat Sep 10, 2016 8:05 pm
If I am partial to a slightly less traditional treblebooster (I like gain, the ability to clean-up) in the sense that I want something that helps to add bottom punch and slightly warmer/rounder highs than normal? Kind of want a Rooster that can be used with a myriad of amps. Should I look for a specific transistor type, or do they all kind of have the ability to do what I mentioned? Thanks so much!
guitmatt
Post by guitmatt » Thu Nov 03, 2016 6:06 pm
CV7355 & Phillips BC109 :alizee:
frost
Post by frost » Fri Nov 18, 2016 12:18 am
Hi there,
I am new here so my breadth of knowledge is small. Can anyone explain what the current difference is btween the RR10 Red Red Roosters and the RR09 Red Roosters? I have a 2015 model RR10 with OC78 transistors currently and it sounds phenomenal. However, as my favorite GAS saying goes: "if one is good, then more is gooder".
Thanks and take care,
Heiko
stella_blues
Post by stella_blues » Sat Nov 19, 2016 1:01 pm
Same thing really, RR-09 is named as a Germanium Booster where the RR-10 is named Amplitude Booster. This way the Captain can change things up transistor wise, putting in silicon trannnies like in the green "hulk" booster above. :tu:
frost
Post by frost » Sat Nov 26, 2016 6:08 am
stella_blues wrote:Same thing really, RR-09 is named as a Germanium Booster where the RR-10 is named Amplitude Booster. This way the Captain can change things up transistor wise, putting in silicon trannnies like in the green "hulk" booster above. :tu:
Thank you for the answer. It makes sense to me now. Take care, Heiko.
fendersilver
Post by fendersilver » Wed Feb 01, 2017 10:33 pm
This little bugger slays! :phpslayer:
________________________________________________________________________________________
"There is no finer sonic-producing weapon for a guitar slayer than a hand crafter Gibson masterpiece."
Fuzzz
Post by Fuzzz » Wed Feb 01, 2017 10:47 pm
Nice! :party: I had an OC140 starlight Rooster and it sounded amazing. Npn too :crackjam:
Logic should not interfere with determination
ombudsman
Post by ombudsman » Tue May 08, 2018 7:29 pm
Can anyone give some insight on which of the various models and transistor variations of the Red Rooster would be the most hi fi, lowest gain, best cleaning up version ?
I have a Supa Rooster (OC43) and love it for some things, and noted the Captain's description that it isn't as hi fi as the RR-10. But I'm not clear on where the RR-10 sits relative to the other models, or which transistor is best for this. I am trying to just get some more treble and just a little gain that is hard to tell from amp crunch, that cleans up entirely without losing treble when I roll back the guitar volume a bit.
A couple of my favorite amps have old hammerite alnico G12s which have little or no doping; they give up harmonics earlier than other speakers, so any kind of pedal can quickly start to do a sort of broken amp/speaker sound. I'm using low output single coil pickups already, Hilotron and Fransch, so I have nowhere to go on that end.
I don't mind searching for an older specific version of the pedal if need be.
