Rotosound Mark III
Re: Rotosound Mark III
Thanks EW!! I knew you'd be able to straighten that out. I know I have seen reverse boards with late '70 and '71 Erie codes. I guess '70-'71 was the switchover to the "Non reversed" board. Maybe they were making both as they were using up the last Erie pots in '70-'71?
The one that always leaves me scratching my head is this one MKIII with all the extra caps and two diodes...? I thought it was one I had, but it is another with a copper q3 and two NKT223 type.
I wonder what all those extra caps do?
- jetofuj
- rafmax
Re: Rotosound Mark III - Vox TB MKIII 2G371
Hi,
here is another MKIII with what could be (or not) an original unusual transistors trio
- rafmax
Doesn't sound right to my ears right now. Plus,it sounds gated right now... This pedal has no balls (for now)
I'll have to check if capacitors are ok. Pots are clean.
Could be the diode polarity
- rafmax
- rafmax
By the way, I discovered that my Sola MKIII (ex Innerflight's) has a link between two of the fuzz pot pins
Damn, three MKIII, none are acting and looking the same... welcome to 40+ year old pedals world
Some of them have a reverse fuzz control, some a regular one. Do they behave differently?rafmax wrote:By the way, I discovered that my Sola MKIII (ex Innerflight's) has a link between two of the fuzz pot pins
- rafmax
Users browsing this forum: No registered users and 40 guests
