I started a "Fuzzy website" !
- DiscoFreq
Re: I started a "Fuzzy website" !
You should specify the space between lines (in css or in the paragraph tags?), adding empty lines gives too much space in between...
EffectsDatabase: http://www.effectsdatabase.com
26000 pedals, 4000 brands
The website editor for freewebs doesn't have that option - at least that I've found.DiscoFreq wrote:You should specify the space between lines (in css or in the paragraph tags?), adding empty lines gives too much space in between...
it's not really a spacing issue. it's a boldness issue...
Which is bizarre, since I didn't use the "bold" command ...but yours DEFINITELY looks fatter and bolder....Electric Warrior wrote:it's not really a spacing issue. it's a boldness issue...
- DiscoFreq
Maybe not everyone has this font:Dragonfly wrote:Which is bizarre, since I didn't use the "bold" command ...but yours DEFINITELY looks fatter and bolder....Electric Warrior wrote:it's not really a spacing issue. it's a boldness issue...
Code: Select all
<font color="#009deb" face="Book Antiqua" size="5">
Could be...but I thought that was one of the "standard" ones. Maybe not ?DiscoFreq wrote:Maybe not everyone has this font:Dragonfly wrote:Which is bizarre, since I didn't use the "bold" command ...but yours DEFINITELY looks fatter and bolder....Electric Warrior wrote:it's not really a spacing issue. it's a boldness issue...So some people see this font, other people see a different (default) one?Code: Select all
I'll scroll through the other available fonts, but I definitely don't want the site to be too plain or boring.
I changed the front page font to "Georgia"... does that look any better ? (You can compare to any other page)
Oh..I also increased the size along with changing the font...my old eyes like the bigger letters better !
I do have book antiqua regular..
edit: Georgia has the same problem. must be a mac thing. tried it with safari and firefox.
your old eyes might like the bigger font better, but I think it looks way oversized. and most browsers have a text zoom for the visually impaired.
BTW - I'm looking for a gut shot that I can use for a Mosrite Fuzzrite, later silicon version - the one with the Sprague / Sierra circuit encased in epoxy....I had some but they seem to have disappeared.
Users browsing this forum: No registered users and 29 guests
