Rooster to push a fuzz or distortion using clean amp
Tonal shaping & volume boosting delivered with germanium love.
ians371
Post by ians371 » Mon Jan 30, 2012 11:21 pm
Hi noobie on D.A.M. from Sydney Australia.
I am looking at a DAM Red Rooster as a treble boost but want to run my VOX AC15HW1 Clean as I do not have loop for delay,reverb,modulation etc.
I want to be able to use delay and modulation with dirt without sounding like crap.
I already have a Skreddy Pink Flesh and a Fulltone Plimsoul and was wondering if anyone had experience with using the Red Rooster to push other pedals rather than an overdriven amp?
I am also looking at using the Rooster to push a drag n fly into sear land.
Anyone had any experience with this approach.Especially with a VOX ?
Cheers
Ian
jagermonster
Post by jagermonster » Mon Jan 30, 2012 11:24 pm
I've used a booster to push a DOD 250 or a Rat into saturated fuzzy territory. It's pretty awesome, but I still prefer Fuzz --> booster.
Be prepared and be honest.
pothole
Post by pothole » Mon Jan 30, 2012 11:26 pm
Welcome to the forum. I'm running an AC15HW1 as well and would say that a Red Rooster is required for your setup for what you want to do. It's the magic button.
ians371
Post by ians371 » Mon Jan 30, 2012 11:32 pm
Thanks for rapido feedback guys.I looks like I am on the right track.Anyone used a Skreddy Pink Flesh ??? Gilmour in a box....
devnulljp
Post by devnulljp » Mon Jan 30, 2012 11:37 pm
You can also run a wet/dry rig to get the delay after the dirt -- Suhr makes a cool little box that goes between amp and speaker and run the out to a power amp into speakers. That way you get your amp distortion before delay.
ians371
Post by ians371 » Mon Jan 30, 2012 11:42 pm
Thanks for that will check out Suhr on that.
devnulljp
Post by devnulljp » Mon Jan 30, 2012 11:55 pm
Here you go: ISO Line-Out Box
ians371
Post by ians371 » Tue Jan 31, 2012 12:00 am
Thanks,
superfuzz
Post by superfuzz » Tue Jan 31, 2012 12:34 am
That suhr box it a brilliant little trick I'm to have get one.
Thanks for the headsup
ians371
Post by ians371 » Tue Jan 31, 2012 1:31 am
With a VOX AC15HW1,Single speaker,how would my signal chain be set up to incorporate the Iso Line-Out box.
How would I separate my dry (EQ,Boost,distortion,overdrive chain) from my wet (Modulation,Delay & Reverb chain) ?
Will I need a separate speaker cab to split a wet signal to the external cab and the dry to the amp speaker.
Getting confused as to how a wet effects loop post power amp and a dry effects loop into front of amp using this device.
Would I need an ABY to split signals ?
Has anyone got any simple signal chain layout and connections diagram to set this up ?
Cheers Ian
