THREE new pedals from Fredric Effects
Up and coming builder? Sell your creations here...
timhulio
Post by timhulio »
Fredric Effects are proud to announce the Verzerrer, Utility Perkolator MkII and Dresden Synth Fuzz MkII. Three unusual effects pedals in our newly designed wedge enclosures with top-mounted jacks.
These are all £140 + p&p (£5 UK, £10 Europe, £13 ROW)
Verzerrer
The Verzerrer is a highly tweakable recreation of East Germany's only distortion effect, the Bohm Trickverzerrer, using original old stock transistors and diodes. Originally produced in the 1960s and 70s, the Bohm Trickverzerrer is a somewhat abrasive and characterful distortion pedal, which lacked some practicality in that it used 5-pin DIN connectors, a plastic enclosure, and trim pots which had to be adjusted with a screwdriver. The Fredric Effects Verzerrer uses original components and can be considered an exact recreation of the circuit, but it also adds practicality, featuring these trim pots externalised, an input gain control and a series of DIP switches on the circuit board for further adjustment.
http://www.fredric.co.uk/verzerrer
The Utility Perkolator is our improved version of the fabled 1970s Interfax Harmonic Percolator. The Harmonic Percolator is a simple yet fascinating circuit which readily lends itself to tweaking and modification. Using higher gain, lower leakage Russian Germanium transistors, and a low pass filter which only removes the high-end hisses and glitches associated with the HP, the Utility Perkolator has a considerably lower noise floor and more predictable note decay. *NEW* Now with added ring modulation circuit for octave/splattery overtones.
http://www.fredric.co.uk/utility-perkolator
The Dresden Synth Fuzz is a quite unique pedal. Combining two synthy-sounding octave fuzzes run in parallel - an upper and lower octave fuzz - it covers the whole frequency range. It's dirty and snarly on the low notes, almost like a malfunctioning analogue synth, and relentlessly precise on the higher notes. *NEW* Now with clean blend, plus input gain control to reduce/increase glitchiness.
http://www.fredric.co.uk/dresden-synth-fuzz
Doc Holliday
Re: THREE new pedals from Fredric Effects
Post by Doc Holliday »
Ooh very nice
In order to get a loan, you first need to prove that you don't need it.
MEH!
Post by MEH! »
Agreed, very nice!
Laservampire
Post by Laservampire »
Love my Utility perk
Ben
kosta
Post by kosta »
That Verzerrer sounds great!
