Show off your builds!
peps1
Re: Show off your builds!
Post by peps1 » Thu Feb 27, 2020 1:58 pm
Added the metal Balance/expander/tone label to the new builds (if you have one of the old ones without this, just PM me and I will post you one out :tu: )
simonm
Post by simonm » Sun Mar 08, 2020 5:08 pm
mutant '54 blacktop LP style:
Musoo (Chinese) custom kit with semi-hollow body and big neck, took forever for them to make it but it eventually arrived end of Jan, just before Corona got serious. Not perfect (pickup routes too big, wtf), but the important things (neck + weight) were good, and I was sick of waiting, so I accepted it as delivered. I got this one to replace the older heavier one behind it. Pickups are now out of phase and it has a Freeway 6-way switch, for series/parallel switching and Esquire 'Eldred mod'-style cap option on the bridge pickup - a '50s Kay kleenex box unit in a dogear P90 cover. The neck pickup is a '50s wind Lollar which was a bit bright, so put a nickel cover on it - much better (might spray the cover black? dunno). The wraparound is an orig '53-4 'thin ear' type.
Anyway it sounds great and weighs about 6 pounds. Happy!
a slightly odd top carve, no? [edit it is symmetrical, just looks off in this light] is this typical of any particular period? don't know much about LPs apart from Juniors
body:
fuzz, on Flickr and instagram too
CraigBeckGuitar
Post by CraigBeckGuitar » Sun Mar 08, 2020 10:10 pm
:drool3: Hey Matt, What are each of these pedals? They look awesome!
Jim Goad
Post by Jim Goad » Mon Mar 09, 2020 9:37 am
Looks really good! I’d leave the neck pup cover as is. Adds to the custom look.
simonm
Post by simonm » Mon Mar 09, 2020 6:25 pm
Thanks.
Yeah, will probably leave it...
Arcane
Post by Arcane » Fri Mar 20, 2020 10:08 pm
Mojotastic
The-kangass
Post by The-kangass » Sat Mar 21, 2020 12:51 pm
due to quaranteen I'm finaly able to catch on to populate some third party PCBs - today fuzzdogs echoblue with added oscilation switch and 100k time pot for some serious glitch and grime :-D
pretty close fit in this tiny Edystone 27134PSLA enclosure :marx:
Arcane
Post by Arcane » Sat Mar 28, 2020 1:52 am
Isolation Blues
Dr Tony Balls
Post by Dr Tony Balls » Fri Apr 10, 2020 1:31 pm
I posted about it a while ago when it was forming but this is the result of the charity run I did for the Electrical Audio forum. This is the second year i've done it so it may be an annual thing now. For this one a Muff-style circuit is the basis. The tone control has been changed and is very not Muff. No mid scoop, more like a treble roll off. The gain is set up a bit lower, more like a Russian muff, with lower threshold, smoother clipping. All of that is wrapped in a wet/dry blend circuit that helps it play better with lower register instruments. 30 units made, with $1500 in proceeds sent to cancer research charities.
simonm
Post by simonm » Fri Apr 10, 2020 2:35 pm
great stuff Tony!
