POST YOUR PEDALBOARD
- Markusgit81
Re: POST YOUR PEDALBOARD
Todays Live Board
- D437B853-224F-40CF-A4C2-5853551FC7A6.jpeg (1.16 MiB) Viewed 1315 times
Fuzz and Wah ‘off board’ the way it should be
Nice!
What amp and guitar you play with?
- Markusgit81
- moose
Here's my current board for Wild Rocket and some irregular psych and kraut jams we have between a bunch of mates here. Hopefully it won't change for quite a while.
The brains per se is the bottom right box. This has an active splitter with phase switch, a mute for each output plus a modded Sunn Beta preamp replica. The Beta goes to the DOD eq, Meatbox clone and Hi-band Flanger which all run into a HB Bass Block 800 and a 1x15 for my "clean" low/low mid side.
The rest runs into the echo return on my Sound City 120 and a second 1x15. Some gigs I'll the top and bottom of an 8x10 in the same sorta configuration. The Nomad and Sledgehammer are in the parallel loop of the Sy-1 and I generally have one or the other on all the time. Then I have the Lantern Rowan Flanger and Ross Phaser for various parts. Then the Sundrive and Cosmic Trigger are always on for my core base tone. The Sundrive is set with gain at zero and I find it really helps to gel the dirt and synth tones together as a sort of very gentle natural compressor. I use the boost on the Sundrive the odd time playing clean to get the level up a bit but generally it's left off. Likewise with the Cosmic Trigger boost.
All powered off a pair of Strymon Ojais with some daisy chaining.
PS knobs may not be set where I usually have them..
- pothole
Echomachine for the win!
