I'm on a bit of a long-term restoration project at the moment. Here's how the fuzz box looked when I got it:
The previous owner had chopped out all the apparently broken bits and discarded them, and this being the best fuzz box to come out of the 1960s, I wasn't gonna settle with brand new bits if it could be helped.
I harvested another Arrow switch from an early Colorsound wah (sorry!) and I'm really happy with how it looks, both inside and outside. I also did an operation which I devised with another Project V where I set the power arrangement up in such a way that I could actually use the pedal with a modern 9v battery, but if for whatever reason things got really absurd and I wanted to use the obsolete long cylindrical 8.4v batteries that these pedals were intended for, then one of those would still be usable. Basically I found some cheap new battery contacts that were close to the dimensions of the original sort, bent them into shape, and then attached them to the case using the existing holes. I then wired up these fixed battery terminals to the main circuitry of the pedal (using the the correct mix of red and grey colours!), and also hooked up some modern PP3 snaps via solder tags to those new fixed terminals. In short, we've now got two different power options running in parallel, without making any further modifications to the electronics or the enclosure.
The widow who sold this pedal to me had a pair of grimy old knobs that were apparently stored together with the pedal. They're definitely not original, and they're pretty ugly too, but until I can find a pair of rare WEM knobs (the circular type, without the pointer), these'll have to do. This very specific version of the WEM Project V would have also had mismatched pots to begin with. It would be pretty easy to stick in an old AB pot of the same sort as the existing volume control, and it would look great, but it simply wouldn't be forensically-perfect. I need to find a Morganite and this will probably take a few years. I also need to make a new cover for the 'battery hatch' out of a small rectangle of steel, and I don't have the tools for that (yet). So yeah, pedal works again! and sounds amazing as expected! ... but there's more work still to be done
