Sickle wrote:
Its even betterer.
Impex MKII...
- Sauniere
Re: Impex MKII...
Re: Impex MKII...
Dear Sickle, once again I will remind you mine is a MKII.Sickle wrote:Phillip's Sola box is a 1.5, mine is an MK II. Different circuits, but close buddies!Sauniere wrote:
Re: Impex MKII...
Perhaps from Dave saying it was ''the most MK1.5 MKII he's ever made!'' ?Sickle wrote: Where do I keep getting the 1.5 thing..?
It's based on Graham's blanked out sol/vox MKII, but it's been voiced to suit my own particular needs which veer towards the lower gain end of the Tone Bender spectrum.
The circuit is a MKII circuit though, it just has a wide range on the attack knob.
- Mr. Min T. Fresh
Re: Impex MKII...
Oh yeahSickle wrote:Mine is not Impex, don't worry!
Its even betterer.
I have a big dick and I challenge you to swallow it or fight me strait up.
Re: Impex MKII...
I had a go at the It Might Get Loud page sound...
http://s51.photobucket.com/albums/f395/ ... arison.flv
Re: Impex MKII...
Nice work, sir. The note decay and the fuzzy characteristics sound pretty damn close, ay. Its all too obvious now, Jimmy Page in fact used a D*A*M made MKII
- Blobcaster
Re: Impex MKII...
Page wishes he had a MKII ......
Re: Impex MKII...
Is it pretty much the exact same circuit/sound as my SupaFuzz too?? They are exactly the same (Graham's Vox MKII and my SF, right?) You are making me lust after mine!!! I found with the SF, it sounded best with the Volume all the way up, and the Filter/Attack backed off just a hair from maxed out...going to have fun 're-discovering' that pedal!!Philip wrote:Sickle wrote:
Re: Impex MKII...
The Captain wrote: Its all too obvious now, Jimmy Page in fact used a D*A*M made MKII
I think it is, but I guess Dave would be the one to answer that.theemadcap1 wrote: Is it pretty much the exact same circuit/sound as my SupaFuzz too?? They are exactly the same (Graham's Vox MKII and my SF, right?) You are making me lust after mine!!! I found with the SF, it sounded best with the Volume all the way up, and the Filter/Attack backed off just a hair from maxed out...going to have fun 're-discovering' that pedal!!
The impex MKII has been tuned to suit my particular needs though, so there's probably some differences.
Re: Impex MKII...
Same transistors but tuned a little more precisely. I actually had three Impex loaded MKII variants to hand when building Philips, the early Vox MKII and two Impex Supa's. Fuzz overdose
The Impex transistors seem to give a very board sweep on the Attack so you can achieve a really clean tone (for a MKII) at zero but still a very fierce amount of balls at full Attack. I just took this to an extreme on Philips MKII so the pedal would get into low gain territory pretty easily and also have some very subtle gating in the higher gain settings.
Users browsing this forum: No registered users and 12 guests
