RR10 Amplitude Booster
- Fuzzz
Re: RR10 Amplitude Booster
so are these going to be the new Rooster or a different flavour like the FR70/69??
Logic should not interfere with determination
Same shit different box. Basically I was trying out using a Hammond made enclosure again, like on the first Roosters I made. I changed the sub-heading to 'amplitude booster' in case I continue with the enclosure type so it frees me up to make silicon versions as and when requested/required.
I started the numbering from #000 on these due to the above and also that I would be making these units myself. The only circuit change on these units that went to DSM was the addition of 470 ohm resistor tied on the boost pot, so that when the boost control is zero'd there is still a slight signal pass. All had Mullard OC82DM's and were mid to high gain types.
- mjkk
- jetofuj
- cajone5
I like your style, Dude.The Captain wrote: The only circuit change on these units that went to DSM was the addition of 470 ohm resistor tied on the boost pot, so that when the boost control is zero'd there is still a slight signal pass.
- Markoni
- Funky Druid
