Right, so I'm going to build a Fuzz.....
CONAN
You cajn't bajn me
Re: Right, so I'm going to build a Fuzz.....
Post by CONAN »
Nice sound Dragonfly - very cool.
kristo
Post by kristo »
Well having just sat my most recent exams before xmas I now have the time to actually see this through before the next lot start
in April. After thinking about it for a while I've decided to follow the advice of Tatter and others and buy a kt. I just need a soldering station.
Can anyone recommend one the will last me a good while and is easily available in the uk please?
Jim Goad
Post by Jim Goad »
I've got a ZD Electronic Tools ZD-929C Temperature controlled soldering station with LED display (catchy name huh?). It's cheap & OK but you should get something better because a good soldering station will make things much easier & more enjoyable.
A multimeter (they're quite cheap) & some sort of heat soak for the more delicate components will be very useful.
kristo
Post by kristo »
is this the kinda thing, or is it a bit overkill:
http://www.maplin.co.uk/Module.aspx?ModuleNo=98133
in the sale it looks like a good deal, or could i get one for cheaper than is more than adequate.
The Captain
Post by The Captain »
Fuck that. Buy an Antex. Low cost, high quality, light weight, super efficient, made in the UK and built to last. What more could man need. :tu:
http://www.rapidonline.com/Tools-Fasten ... rons/73126
http://www.rapidonline.com/Tools-Fasten ... tand/30324
You don't need non of that LCD mumbo jumbo :hihi:
kristo
Post by kristo »
cheers captain. It's just i thought i'd read somewhere that having a temperature controlled solder is better for building pedals, but this could easily be wrong! I'm just keen to start out on the right foot with this and don't wanna buy stuff I dont need and will never use. Even with those solders, do you go for the normal, the silicon? nothings ever straightforward.....
kristo
Post by kristo »
looking at in again the silicon just seems to be a heat protected cable, which safety wise makes sense, so the real question is 18w or 25w? does it matter?
The Captain
Yeah good choice on the silicon. You can never be to safe in this day and age. :tu:
We do use both the 18 and 25's but does depend on the job. Linzi for example can get by on the 18 if she is building Meats. I'll use the 25 if I need to ground the back of a pot. Its about how much heat you want to pack into a punch.
I'd say the should 18 should do it. Bare in mind these are designed for lead free solder so the efficiency is far superior to a regular soldering iron of this type.
You'll need at least 2-3 tips. You'll get a far sized one with the iron with is cool for jacks and pot lugs. 0.5 is good for making boards.
http://www.rapidonline.com/Tools-Fasten ... rons/70891
You'll also need some of this shit.
http://www.rapidonline.com/Tools-Fasten ... tent/70881
Remember, these are the iron's that work well for me. You might find something you get on with better. I've tried a shed load of bells and whistles set-ups and personally I thought it was over kill. Pedal building it really straight forward so my thinking from day one was why over complicate things. A light weight good quality iron has worked well so far.
1bottlerocket
Post by 1bottlerocket »
kristo wrote:looking at in again the silicon just seems to be a heat protected cable, which safety wise makes sense, so the real question is 18w or 25w? does it matter?
I think it is the amount of heat the iron produces, from what I understand the 18w is safer but the 25w is quicker. I use a 40w myself but you have to be quick about your work. I also use heat sinks when working and they help a lot.
1bottlerocket
Thanks for the info Dave!
Users browsing this forum: Semrush [Bot] and 0 guests
