Show off your builds!
Re: Show off your builds!
Data dump.
All red Super Black:
Moon Unit delay & verb:
BF-15 combo. 2 x EL84, 15 watt amp with preamp in the 60's Fender vein. Lots of clean, lots of chime, and grit if you wanna crank it. 1x12 combo with a Jensen C12N. Added post-phase inverter master volume to keep it chill when needed:
BF-15+ combo. Really very similar amp to the one posted above but with a tip in the other direction. No master volume, but an added and switchable Rangemaster/Ballsmaster style boost to the front end. Plays the same as if you had a RM pedal or amp-top unit in front of the input, but all internal. Transistor is a Soviet MЛ38a.
So. Fekkin. Gnar.
- squarewave
- Radiotron
That's some amazing work there Tony! Absolutely love the built in rangemaster!
THANKS!
Voomp!
This had been a wall hanger in a bar or venue for years and was covered in crud and falling apart. I only hung on to it because of the ‘Okay Hot-Shot Okay’ artwork.
70s Jedson pickup, 70s Japanese bridge, 70s Shaftesbury knobs, 90s Hohner neck bolted to a reclaimed pine centre block. It’s crude and rude but plays and sounds ace.
- Radiotron
Beautiful work as always!!
One tube reverb?
One tube reverb?
Yup. Bit more subtle than the Fender standard but does the job well enough for most needs.
