Red Rooster Power Supply?
hyeronimusss
Post by hyeronimusss » Tue Sep 20, 2011 10:24 am
Use positive ground powering system, not the usual negative grounding. Some say it sounds better with batteries, and they last quite long on this one...
stratguy23
Post by stratguy23 » Wed Sep 21, 2011 4:48 am
Cool thanks, I will compare it using power vs. battery
stratguy23
Post by stratguy23 » Fri Sep 23, 2011 2:45 am
Update: I used a reverse polarity cable and it didn't work, the pedal did not power up. I just put a battery back in it, and it powers up fine. The transistor is an AC128. Should I try to run it off regular power without the reverse polarity cable?
The Captain
Re: Red Rooster Power Supply?
Post by The Captain » Fri Sep 23, 2011 11:00 am
Do you guys actually read that bit of paper that comes with the pedal? :badteeth:
The unit comes fitted with a heavy-duty 9-volt battery which is activated via the insertion of a plug into the “IN” socket. Always unplug your cable when not in use to lengthen the battery life. This unit can also be powered by a well regulated 9 volt power supply with a Negative centre and Positive barrel.
The RR-09 operates on a POSITIVE GROUND powering system so therefore requires its own power source or an individually isolated multi-way power source.
A 2008 Rooster will be negative ground so will run of a daisy chain so does not require an isolated supply.
If a Rooster is eating battery juice and you ain't unplugging the cable you are burning a hole in your pocket. Unplug it and save some bread! :tu:
All D*A*M Stompboxes use the same wiring on the DC socket regardless of grounding polarity. Negative centre and Positive barrel.
