Bias on the Super Bee
Germanium fuzz tones for old school heavy minds.
modeerf
Post by modeerf » Sun Jan 29, 2012 4:01 pm
I would have to strongly disagree with the "vox and bee don't mix statments" I've found it to be one of my favorite combinations. The trick is to dime everything on the bee into the vox slightly pushed. Becomes a new beast, a wretched one at that but transforms into a spitty little nightmare. Perhaps not what you were looking for but it is an unruly, all out mother fucker. Sounds like a maestro fz-1a and a superfuzz had a spoiled little illegitimate devil child. Quite impressive!
Do Drugs, Worship Satan.
anemochore
Location: Outside of Suquamish at the bottem end of Hawkeye's trail next door to Nooshkum
Post by anemochore » Tue Feb 21, 2012 8:41 am
modeerf wrote:I would have to strongly disagree with the "vox and bee don't mix statments" I've found it to be one of my favorite combinations. The trick is to dime everything on the bee into the vox slightly pushed. Becomes a new beast, a wretched one at that but transforms into a spitty little nightmare. Perhaps not what you were looking for but it is an unruly, all out mother fucker. Sounds like a maestro fz-1a and a superfuzz had a spoiled little illegitimate devil child. Quite impressive!
Yes, you are sure right here. I found I like it in the Top boost It's all Good Thanks!
6strung
Re: Bias on the Super Bee
Post by 6strung » Sat May 26, 2012 11:47 pm
anemochore wrote:So now I have a Super Bee and it has much more bottom end than my D*A*M Sola Sound. The Bee works well with my Marshall MKII and sounds great when placed after my Morley Wah. But when used with my Vox AC30 it has too much (I like to use the normal channel, which has no EQ, for my other pedals and the Top Boost for overdriving the amp). Can I roll off some bass by adjusting the bias? I would never do this without consulting someone with more experience.
I condition the sound going into my sb with an overdrive, or have the amp a little dirty. I prefer the overdrive conditioning going into the sb, then into a clean amp (Dr. Z maz 18) with the preamp low, and the master volume high.
The results is perfect, cleans up when I roll-off the guitar volume, sustains and gives a nice "stangy" fuzz. I set the od so it runs at the same volume as the clean amp, and push the sb volume a bit higher.
With Enough Courage You can do Without a Good Reputation.
anemochore
Post by anemochore » Sun May 27, 2012 12:19 am
That does work vary well. Also found using a bit of clean boost before the SB or a bit of treble boost will push the upper mids and or roll off a bit of the bass.
Same goes for Superbee mode in the 1966 (the 2010 run has a lot of bottom). Makes me want to get a Red Rooster or Mini Driver
SSgt93
Post by SSgt93 » Fri Feb 15, 2013 3:07 pm
I'm really looking forward to receiving my NKT version.
SSgt93 on Twitter & Instagram.
-Steve
6strung
Post by 6strung » Thu Jan 02, 2014 9:51 pm
Try this. Flat out roll the bass down on that amp. A second thing I've learned is to have your amp dirty. If you are using an OD pedal have the OD before the Bee. If your just going into the amp, let the amp be a little dirty, you almost can't have it to dirty.
You'll have to fine tune it, but don't waste much time trying to keep the amp clean and then getting a nice fuzz tone. My main amp is a Dr Z maz 18 which is based on a Vox circuit. Also use a newer AC15. :crackjam:
6strung
Post by 6strung » Thu Jan 02, 2014 9:54 pm
Exactly! That is my approach and it produces sweet fuzz, endless sustain, and others asking how I get that tone. :headbanger:
