Guitar tuned Zeke??
- kb892
Re: Guitar tuned Zeke??
i have one of the guitar versions but not ever having a standard i wouldn't know how they compare. i remember asking Dave to make it with more upper mid emphasis than the standard zeke. shoulda bought both back then who would ever think Mr Main would become so popular!
- TheWarmth
I owned one of the guitar-tuned Zekes for awhile. It was badass and I wish I would have kept it. I have a 2013 bass Zeke and it sounds very different on guitar than the guitar version did. I appear to be in the minority here: I wouldn't use my (bass) Zeke on guitar. I found one setting that sounds pretty good, but to my ears, it is clearly intended for use with bass. It'd be awesome if Dave did a new run of guitar-tuned Zekes. Perhaps a petition is in order!
- stella_blues
I think the new Zeke sounds awesome with guitar.....everything sounds huge through it.i like how it adds low end to a midrangey overdrive.
Never tried the guitar tuned Zeke, a petition to Dave would be a great idea, I'd love to hear the difference side by side. Maybe every 5th or so batch should be tuned accordingly
stella_blues wrote:I think the new Zeke sounds awesome with guitar.....everything sounds huge through it.i like how it adds low end to a midrangey overdrive.
new zeke + guitar + big fuckin tube amp =
I partially agree with this, although I haven't tried a guitar tuned version. The germanium setting and to some extant the silicon diode setting can sound a bit lackluster on guitar, and they sound fantastic on bass. But, I find the LED and no clipping settings are fantastic on guitar. And recently recording with the zeke on guitar I found that the germanium setting does have its uses for guitar, especially when combined with another drive pedal. I ran my monolith oracle set to a crunchy grind into the zeke on a germanium setting with the blend about halfway and it added a wonderful girth and harmonic edge to the tone I wouldn't have been able to achieve otherwise. So with some experimentation I've found it quite useful for guitar. I agree with you thought Paul, it really shines on bass heavy signals...through my moog synth it's just monstrous!TheWarmth wrote:I owned one of the guitar-tuned Zekes for awhile. It was badass and I wish I would have kept it. I have a 2013 bass Zeke and it sounds very different on guitar than the guitar version did. I appear to be in the minority here: I wouldn't use my (bass) Zeke on guitar. I found one setting that sounds pretty good, but to my ears, it is clearly intended for use with bass. It'd be awesome if Dave did a new run of guitar-tuned Zekes. Perhaps a petition is in order!
- Yggdrazil
Exactly what i think about it on guitar but I still need to try it on bass; so, i will take all you said as a guide in my further experimentationredeyeflight wrote:The germanium setting and to some extant the silicon diode setting can sound a bit lackluster on guitar, and they sound fantastic on bass. But, I find the LED and no clipping settings are fantastic on guitar.
Instagram:@Stonefly_effects
Personally, I wouldn't ever recommend the Zeke for guitar use. Sure, it works and all and for some it could be a truly great thing but ultimately it is intended for use with bass instruments.
The gain structure, frequency response and the general set-up of the pedal is all about the 4 string mother fuckers. I emphasise the personally part above as I really would not care to use the pedal on guitar myself, too little gain, too heavy in the lows, not enough midrange punch, and that amount transparency on guitar I would not care for, horses for courses though innit.
Guitar tuned version? Ain't gonna happen. Don't see the point. I think it's a pretty decent dirt box for bass, it would be mediocre one for guitar. Buy a Klon, or be a man and play bass
Hey Captian how do you set the zeke for your bass rig?
Silicon. Drive a crack over noon. Treble and Level backed off a teeny tiny bit. Blend just under half way. Rickenbacker and Orange pretty dirty to begin with. Rics tone half closed. It pretty much acts as a second channel.
- jetofuj
I use it as a dirt box, so treble and drive maxed with 25% of clean signal.
If you want more of a tube sound than dirt, then start with treble, drive and clean signal half way on silicon or led setting. It fattens the sound, especially if you're using solid state amp.
Users browsing this forum: No registered users and 10 guests
