Something new!
Magnetic Effects Midphora. A fixed wah with clean blend and switchable range.
Many classic lead tones were recorded with a wah left in one position instead of being rocked back and forwards. This is commonly referred to as ‘fixed’ or ‘parked’ wah. This sound has been used in some of the most famous recordings of all time by great artists such as Jimi Hendrix, Jimmy Page, Mark Knopfler, Mick Ronson, Michael Schenker and Marc Bolan to name just a few. The Midphoria allows you to access those classic tones in a smaller, more convenient pedal!
Unlike a traditional, large Wah Pedal where you have to move the treadle around to find the exact tone you are looking for when playing, the Midphoria allows you to dial in the ‘Sweet Spot’ using the Sweep Control. You can then access this tone by simply turning the pedal on and off using the foot switch. In addition, you can extend the frequency range with the Frequency toggle switch. The Clean Blend allows you to dial in the dry signal so you can balance the amount of Fixed Wah style mid boost. You can go from a subtle hint to all out mids!
The Clean Blend has enough output level to be used as a booster on its own. Turn down the Fixed Wah Volume and crank the up Clean Blend for a great sounding boost!
All these features add up to make the Midphoria a great sounding and easy to use pedal that integrates well into a modern pedal board.
FEATURES:
Top mounted Jacks and DC socket
Volume, Clean, Sweep and Range Controls.
High input impedance and low output impedance
True bypass switching
9-18V DC centre negative adapter powered
Handmade
£109 plus shipping.
http://www.magneticeffects.net/shop/midphoria
Magnetic Effects MIDPHORIA
- Chugs
- Chugs
Re: Magnetic Effects MIDPHORIA
Clips sound really great. Between this and the Double Feature, you're the king of fixed wah.
- Lee
Very cool pedal Chugs
- Chugs
Thanks guys!
Yeah congrats dude
- chankgeez
Yeah, those clips sound great.
I still think having an expression input would be super useful though.
0
